03-17-2010 11:05 AM
I am having a problem with a cRIO application and a NI 9213 module. I have a heater application and I am using the NI 9213 to read the temperature values of the heaters.
When I am using the heater to heat the system, the NI 9213 suddenly (after reading for a few minutes)stops updating the temperature values and is stuck to the old value. The time and temperature at which it gets stuck is different every time. I have some other analog and digital modules in my system and they continue updating without problem
I verify my loop an it never stop, but by any reason the thermocouple reading stop updating the values. I am running in scan interface. Any help to solve this issue will be greatly appreciated. I am working in a new application with a short dead time.
Thanks!
03-17-2010 11:25 AM
Hello nausfaratu,
Would it be possible for you to post your code?
Also, I'm curious what steps you have to take to get your 9213 working again?
Sebastian
03-17-2010 04:10 PM
Hi Sebastian,
To get the 9213 working again I have to reboot the controller or make any change in the module properties like change from "hi rtesolution" to "hight speed" or something like that.
Attached is my code. It just a vi to test my inputs and outputs.
03-17-2010 04:59 PM
Hey nausfaratu,
Thanks for the code. It is likely not related to the issue you have reported, but I recommend wiring all the variable nodes in series using the error wires. I see you've done that for a few nodes, but not all. This should provide a significant performance gain.
As for the bad data, I should have asked earlier, what version of RIO / LV are you using. I'd like to set up a system and see if I can reproduce the issue.
Sebastian
03-17-2010 05:13 PM
Apparently solved due to an electrical grounding issue, see:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=471162
-AK2DM
03-17-2010 05:25 PM
Glad to hear it!
03-17-2010 05:43 PM
That's right,
the problem was bad grounding.
Thanks all of you guys for your support.
