03-16-2005 12:26 PM
03-16-2005 02:28 PM
03-16-2005 02:30 PM
Is it always the same channels, or different channels every time?
Does it happen on several channels at once, or one channel, then another, then another...
Are you storing these readings in RAM (memory filling up) ?
i.e.: -270 DegC vs the more realistic 35 DegC
Absolute zero is -273.15 deg. C - that sounds like an open channel, falling to the voltage limit.
when a Fluke meter was used to measure the output of the "bad T'couple" it too was giving valid numbers
Possibly the act of probing the terminals corrected the problem by re-connecting a loose connection.
Possibly your temp comp connection is bad?
Possibly the connection from your terminal board to the measurement board, rather than the TC connections themselves.
Blog for (mostly LabVIEW) programmers: Tips And Tricks
03-16-2005 02:40 PM
03-16-2005 04:04 PM
04-14-2005 10:55 AM
04-14-2005 12:58 PM
That pretty much eliminates your LabVIEW code.
seem to remain bad until the SCXI-1001 chassis is reset
What exactly do you mean by "chassis is reset"? (I'm not a SCXI expert, but I do have a SCXI-1000 chassis here). There is no reset button. It's not hooked up at the moment, so I can't tell if there's a software "reset" function.
Do you mean power Off & On ?
Do you mean a reset button (maybe the 1001 has one, I don't know).
Do you mean a software reset from LabVIEW / Max ?
I don't see how any channel could hang up at 25°C and stay, that's not likely the top or bottom end of your TC range.
Possibly some sample/hold or track/hold amplifier quits sampling, and stays holding.
It IS about room temperature, I wonder if your CJC channel is somehow being read instead?
Ground loops would not likely be the problem, unless there's something else happening when the channels fail (like a welder firing). Even then, it's not likely that a rest would fix that.
My first thought would be to disassemble the SCXI stuff, and look for the usual suspects: dirty connectors, chips not in sockets, loose screw terminals, broken wires. Sounds like hardware to me.
04-14-2005 02:09 PM
04-15-2005 08:35 AM
04-15-2005 10:27 AM
