There must be a better way of doing this
I want to read digital signals from my DAQ and display whether each channel is on/off on the front panel
"If anyone needs me, I'll be in the Angry Dome!"
Message 31 of 46
(1,470 Views)
Aeastat,
Again thanks for all the help, i really appreciate you taking the time to go through all of these steps with me. When they are there in the program i don't have any probs with understanding whats going on - it's just getting them into the program i have trouble with! Smiley Happy, but these step by step ........steps are really helping me to see how to go about modifying and writing programs etc.
again thanks,
Chris
Message 32 of 46
(1,464 Views)
No problem that is what I want. I want you to see how it can be done and be able to understand so you can do it the next time. Also when you have gotten to be a pro at it you come back and pass it on to someone else. That is what this fourm is all about.
Tim
GHSP
Message 33 of 46
(1,458 Views)
You will need digital output to read this. So you will have to edit the daqmx create virtual channel vi so it is a digital output.
18297iDA6110291311F50A
Do you know the difference for an input and output? If you want the device to tell you a state then it would be an output. If you are trying to set the channel state then it would be an input.
Tim
GHSP
Message 34 of 46
(1,455 Views)
Is there a reason that you are using MS word for your reports? I think it would be easier to send everythin to a text file such as .txt or .csv We could do this very easily with the write to spread sheet file.
Tim
GHSP
Message 35 of 46
(1,445 Views)
Ahh i didn't realise that about input/output ( a bit confusing - i thought input collected data and output sent signals outSmiley Happy).
There is a requirement to use Word, as i am trying to put as much automation into the system as possible. And having someone process the data after it has been collected is a step backwards.
Good news though, there is now only one test_number AI, a global one for the whole test cycle. The programming of the tester has been altered so that it queues the packs, before moving on.
I've had a go at trying to make the digital inputs (or outputs whatever they areSmiley Happy) work with the test_number analog channel, in order to display pass/fails on the word report. (See the VI below) My idea is to get the while loop surrounding the digital read to iterate every time the value of the test_number input changes by 100mV. Therefore the digital channel is only read when the test changes.
Then i tried to use a case structure to record on which test the digital channel registered a fail, but i'm not sure if a loop is needed here or how to append the values to an array.
Chris
Message 36 of 46
(1,430 Views)
I would use events to tell the digital loop to take data. We would also need to change the digital loop to read only when it gets this signal. I will look at your code and see what I can do to help here.
Tim
GHSP
Message 37 of 46
(1,427 Views)
Do you have the digital setup file. I can take a look at that and see what you have going on there.
Tim
GHSP
Message 38 of 46
(1,423 Views)
here you go
Message 39 of 46
(1,421 Views)
Do you need to see all of the digital channels to know if there was a failure or do you just need to know if one failed?
Tim
GHSP
Message 40 of 46
(1,414 Views)
