04-06-2018 06:55 AM - edited 04-06-2018 06:57 AM
I am using OWON TDS8204 oscilloscope together with software Oscilloscope PC Suite for TDS series that I got from the official site.
This software allows to automatically save the current waveform in bin format. The problem arises when I try to parse the resulting file.
Through tries and errors I have realised that data (i.e. points of the waveform) usually (but not always) starts with 279th bit and is 8-bit integer. But values of amplitudes are different from the real values (or those that I get if I save the waveform in csv or txt format): they seem being multiplied by a factor of 2.5 . But I cannot be absolutely sure about this. More over, I suspect that before the data (i.e. the first 278 bits) there is some setup info which is very useful and sometimes is necessary information.
I would appreciate any help with my problem. Examples of saved forms are applied. I cannot attach bin file for some reason.
Thanks in advance.
04-06-2018 07:36 AM
Hi LRDPRDX,
can't you attach ZIP files?
And can't you ask those, who sold you that software, for a manual?
04-06-2018 07:53 AM
First of all, I wrote to email address from the official site. I have no answer yet. Secondly, here is zip file with saved waveform in three available formats.
04-06-2018 08:21 AM
Hi LDX,
the data is stored as bytes starting from byte 278 (first byte = index 0). The last byte in the file is a LineFeed and should be discarded.
The value of the bytes is calculated as float value := 0.4*byte value+53.2 (for whatever reason)…
The content of the first 278 bytes is to be discussed with the manufacturer of your software.
