The icon could not be written to the application- Labview 2015
Highlighted
Hi all,
  I am using Labview 2015, I am getting an error while trying to Build EXE. The error is
I am using the Default Icon only. 3 months ago I got the same error but that was resolved without any correction. But now I got the same error.
Does anybody know what should I  do this to resolve?
Thanks in  advance
Arunkumar M
(247 Views)
That's a new one. A few things to try:
Is the HD very full?
Check the HD for errors.
Check your antivirus. Modifying an executive, e.g by changing an icon, could trigger security software.
Check for permission issues.
Ensure that the build destination is not monitored by cloud sync (OneDrive, Google backup&sync, etc.).
Is the build destination local or on a network drive?
LabVIEW Champion. It all comes together in GCentral GCentral
(210 Views)
If you found a solution to this please post it.
I have the same problem.
(138 Views)
Accepted by topic author arun575
Hi all ,
Thanks Altenbach , I forgot to reply.
 I found a solution from another threat, It is working, I checked multiple time no error , You will use following link https://forums.ni.com/t5/LabVIEW/Application-Builder-can-t-build-exe-Error-8-occurred-at-AB-EXE/td-p...
Thank you
Arunkumar M
(127 Views)
As a follow up for more referances,
my lvapp.ico was corrupted.
(96 Views)
