The data in the VI's log file is incompatible with the VI's front panel
Hi, I'm saving data into spreadsheet file. After stopping the execution of vi, I opened the excel file and all the data are saving perfectly. The problem is during vi's execution there's an error as "The data in the VI's log file is incompatible with the VI's front panel". Is there any way to fix it?
(3,468 Views)
Take a look at this developer exchange discussion and let me know if it answers your question:
[edit: Site no longer available. Link removed.]
(3,468 Views)
Thanks David! It's working perfectly now 🙂
(3,468 Views)
Can someone suggest me, how to resolve this error "The data in the VI's log file is incompatible with the VI's front panel."...?
This error comesup as soon as top VI starts.
(3,020 Views)
Since the log file format will change when you change the front panel or change versions of LabVIEW, you will need to delete the old file.
(2,993 Views)
The link also did not work for me.
(2,703 Views)
It's not supposed to work and don't make duplicate posts, please.
(2,688 Views)
