The build specifications does not support VIs with dynamic dispatch terminals
Why?
Will it be supported in the near future ?
(2,199 Views)
Hi pacome,
if you could include your project or a code snippet to illustrate the issue you are experiencing, we would be happy to provide you further assistance.
Benjamin
(2,157 Views)
I have delivered multiple applications going back to ... LV 8.2 with Dynamic dispatch terminals.
Are you including the target classes in the build?
Are you searching for them correctly?
Please post an example that demonstrates the issue that lead you to your stated conclusion.
Ben
(2,153 Views)
I wanted to build a shared DLL.
The problem occurs when an input Control is a dynamic dispatch terminal.
(2,147 Views)
"Now that's a horse of a different color!" (Caby, Wizard of Oz, Emerald City Scene).
Yes the DLL spec never knew about dynamic dispatching.
Your best option is to wrap the LVOOP stuff up in wrappers and expose the wrappers.
I'm curious if others have ideas as well.
Ben
(2,143 Views)
