The MassCompile vi is broken when applying the known fix for Error 1052
There is a fix given in the Discussion Forum for Error 1052 (see Document ID 1RABSOBH)
(The fix is to rename the Open/Create/Replace File.vi to OpenCreateReplaceFile.vi)
Unfortunately when I apply this fix it breaks the built in LabView Mass Compile vi which cannot be updated as this vi is password protected.
I then can't use this Mass Compile tool to update all the vi's used in my TestStand sequences to point to the newly named OpenCreateReplaceFile.vi
Could you give the password for this built in LabView vi or better still, is there a fixed Mass Compile.vi available?
David
(2,462 Views)
Hi David2004
You have to rename your VI while all the calling VIs are open (for this, open the main VI).
Then change the name
Then save the modifications
Then it will work.
Cheers.
Doc-Doc
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(2,458 Views)
