The File ABC.vi is not a VI. Select another?
When I attempt to open some of my VIs, I get an error: The file abc.vi is not a VI. Select another?
(2,681 Views)
Does it actually say "abc.vi"? Sometimes when I save a VI, it doesn't put the .vi extension, so when I try to open it, it won't open. I have to manually rename the file to put the .vi extension, and then it will open.
(2,681 Views)
Hello Homero,
The two KnowledgeBases linked below address the issues of LabVIEW reporting a VI is not a VI.
Why do I Get the Error "The File xxx.vi is Not a VI. Select Another?" When I Try to Open a VI on a D...
Why Do I Get "The file xxx.vi is not a VI. Select another?" on Windows 2000?
If these KnowledgeBases do not address the issue, we will need to look more in depth on what has changed since the VI was last successfully opened.
Matt F
(2,681 Views)
