The CWGraph3D control's X,Y and Z axis behave as if they have a loose fit. That is, they do not make their axis minimum and maximum limits correspond to what their data values are but instead round the minimum down and maximum up to some integer increment. This often leaves significant empty space along the axis. LabVIEW's graph has a loose fit property to turn off this behavior. Does such a property exist for the CWGraph3D control ?
