08-25-2026 01:59 PM
LV2021 (21.0.1 32-bits), Windows 11 (25H2 last update 18-08-2026)
Suddenly I can't select text (label free label, string control) using the mouse by clicking and dragging. Also, when I want to rearange the cases of a structure I can select a case by clicking on it but can't drag it to another position. There may have been a Windows update since the last time I used LabVIEW, I realized the problem yesterday and haven't used LabVIEW for a few weeks.
The problem is only with LabVIEW, I can select text in any other application. I have looked at the mouse settings in Windows and at the LabVIEW options but I didn't find anything that can relate to this issue.
Anybody had a similar issue and/or any suggestion?
Ben
Solved! Go to Solution.
08-25-2026 08:13 PM
Hi ben64
I haven't experienced this issue myself, but as a troubleshooting step,
I would suggest restarting LabVIEW and creating a new VI to check whether the issue is specific to the project or existing VIs.
This might help narrow down the cause.
08-28-2026 05:34 AM
Same versions but no issue.
08-28-2026 08:19 AM
