I need a VI that tests whether the digtal input/output channels on a pxi-6527 are working. So say by using an array of checkboxes aligned with a array of indicators, where the first dig input 0.0 is aligned with the first dig output 3.0 and so on.
I'm not sure why you posted the manual instead of whatever code you have have written so far or details on what problems you have. Are you going to do a simple loopback?
Sorry I will try to give you guys a better explanation. I'm very new to LabVIEW.. I might just look through some of the examples. Something might click then.
I hav a problem with a PXI-1002 compute it has two PXI-6527 DIGITAL I/o CARS but when u turn computer on nothing happens turns on but screen black but if I remove the two digital I/O cards works normal could it be the cards are bad is there any troubleshooting you guys recommend
