09-14-2013 11:06 AM
Using LV 2009 on WIN 7 .
When MAX is fired up it identifies the PCI 6221 quite fine and the board passes self test and Reset.
But the Test Panel alone does not show. Tried MAX versions 4.x as well as 5.x with same result...
The card works in my application with no issues.
So why is the Test Panel palying hide and seek ?
09-14-2013 11:27 AM
What DAQmx driver do you have installed?
As noted here: http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248 LabVIEW 2009 is compatibile up through DAQmx 9.7, which can be downloaded here: http://joule.ni.com/nidu/cds/view/p/id/3811/lang/en
02-16-2015 08:54 AM
Ihave the same issue here. Ni MAX doesn't show the test panel, but the hardware is working fine and reset and self-test are also ok!
I'm using a NI 6323 card with following versions:
NI-DAQ 14.0.0f0
LabVIEW Run-Time 2012 SP1 f9
Ni MAX 14.0.1f1
Windows 7 32bit
According to the link provided, these two should be compatible, shouldn't they?
I would be grateful for any help given.
Best,
Nanoger
03-02-2016 05:48 PM
Note that there are actually three pieces of DAQmx software that can be installed:
NI-DAQmx ADE Support
NI-DAQmx Device Drivers
NI-DAQmx MAX Configuration
If you install NI-DAQmx Runtime xx.xx, this is the smallest footprint, and you cannot configure, name, or test devices, only view them and use them in custom-built applications. This is only really the NI-DAQmx Device Drivers.
If you install NI-DAQmx Runtime xx.xx with Configuration Support, you get the bare run-time package but you also get the MAX Configuration, so that you can access things like "Test Panels" in MAX.
The full NI-DAQmx xx.xx package should install all three pieces.
Note that you should always install the ADE (e.g. LabVIEW, CVI, etc.) first, then MAX if it did not come with the ADE (it comes with LabVIEW), and then finally the DAQmx package.
That said, if you installed NI-DAQmx Runtime xx.xx then you will not be able to find a Test Panel option, because the MAX Configuration software is not there. Try verifying that all three of the pieces of DAQmx software are listed under the Software tab in MAX.
