07-06-2006 01:41 PM
I am required (when doing certain tests) to disconnect my
machine from the WEB
when I do and then bring up LabVIEW I get the following
Backup License
7 days remaining .......
What happens after 7 days
why must I be on the WEB to use my purchased and licensed copy of LabVIEW?
Is there something else that I have to purchase?
Please let me know because this is going to become a real problem quickly
07-06-2006 03:32 PM
07-06-2006 05:18 PM
No my license is to my machine
I use LabVIEW every day and I have since it came out
I only ger the Backup License notice when I must disconnect from the web.
Procedure when running a test
If LabVIEW is running shut it down
Stop all web based programs
disconnect from the web (pull the plug)
restart LabVIEW
this is when I get the Backup License notice ( the # of days has been counting down to zero)
IF I keep LabVIEW running no problems, But that is not always possible.
07-07-2006 11:51 AM
jamesz,
2 things:
First, are you removing your network card (is this a laptop?) when you "unplug"? If so, that's the cause of the problem. The network card must stay installed on the PC in order for you not to get this message. Also do you see your computer ID change when you "unplug"? You can find your computer id by going to start>>Program Files>>National Instruments>>NI License Manager>>Display computer information.
If you're not removing your network card and your computer id is changing, go ahead and contact ni from http://www.ni.com/support/ and select the email option.
Chris c
07-07-2006 12:50 PM
07-10-2006 12:37 PM
07-10-2006 12:49 PM
07-11-2006 11:55 AM
07-12-2006 01:07 PM
07-12-2006 01:21 PM
Some more information
LabVIEW version 8.0
windows XP sp2
Computer ID # P8BF-CK9X-LFDY-L5TF
Computer Name LLNL-RF4NQKKQMI
I am required (when doing certain tests) to disconnect my machine from the WEB
Backup License
5 days remaining .......
What happens after 5 days
When ON line from the License Manager
Left window LabVIEW 8
Development System displays a GREEN BOX
Full Development System with MathScript has a GREEN BOX
Associated Software LabVIEW
Software Version 8.0
Product Name Full Development System with MathScript
Serial Number M62X65397
License File Expiration NEVER
Status Activated for this computer
When OFF line from the License Manager
Left window displays LabVIEW 8
Development System displays a RED ! in the box
Full Development System with MathScript has a RED ! in the box
