Tektronix TDS3014 w/ TDS3EM Ethernet-Adapter (LAN): How to interface with Labview?
We use a Tektronix TDS3014 DPO with TDS3EM Ethernet module. There are drivers available for GPIB communication of TDS30xx DPOs with Labview, but Ethernet comm. does not wotk with these. Tektronix does not publish the TCP-/UDP-Ports used for communication, the commands should be the same as with GPIB communication. Has anyone already written some Labview code for this purpose?
(3,775 Views)
I am almost positive that the ethernet module comes with VISA drivers that allow you to communicate with the scope. Install the VISA driver and then make VISA calls as specified by the instructions in the manual.
-jim
(3,775 Views)
