Tektronix DataPlugin extremely slow
I've installed Tektronix_TDS5000 DataPlugin from this URL and reading Tektronix *.wfm files via Storage/DataPligin LabVIEW VIs. It take a very very long time, over two minutes, to read a single 25 million point waveform  from WFM file this way. I understand it's  stored in 8-bit raw binary format and should take no time at all. By comparison, it takes 1 second to load the same waveform after it was converted to TDMS file with 64-bit double-precision, 8 times as big, format.
Is there a way to accelerate *.WFM input to acceptable rates?
Message 1 of 21
(5,652 Views)
is that really how long it takes?
If so there is a huge problem with how Tektronix stores and transfers the data. How are you interfacing with the tectonics device? Is it GPIB Ethernet USB serial?
"Should be" isn't "Is" -Jay
Message 2 of 21
(5,624 Views)
Out of curiousity, how long did the conversion to TDMS take?  I would expect that time to be about how long it takes the data plugin to work (since a data plugin is basically doing the conversion to TDMS-like format).
Message 3 of 21
(5,614 Views)
The *.WFM file is carried over from Tektronix oscilloscope to SSD  on PC with LabVIEW using a flash drive. The file is only ~ 10 megabytes for 10 million samples
I believe the file is just an array of I8 or U8 with some scalar scaling etc. metadata attached, so it should not take long to load.
I can see that "Convert to TDM or TDMS.vi" from Storage\DataPlugin palette spends 99% of time inside "_openStorageWithRootAutoDetect.vi".
Message 4 of 21
(5,613 Views)
Here's few top lines from profiler, looks like it gets stuck in "_openDataStorage.vi":
Message 5 of 21
(5,562 Views)
Here's few top lines from the profiler:
Message 6 of 21
(5,592 Views)
Hello Fedor,
Can you please post your wfm file so that we can have a closer look? Thanks.
Best Regards,
Mavis
Message 7 of 21
(5,575 Views)
Yes!  You, have a problem with the "...Storage data plug-in".......
Just a question here,  What has the TEK AE suggested?  ( They, TEK AE's are not usually incompetent)
I know that sounds " a bit cold-hearted" but, it sounds like a TEK solution, rather than an NI one would be in order!
Message 8 of 21
(5,575 Views)
Here's a zipped  *.wfm attached.
How does one get in touch with TEK AE about this problem?
Message 9 of 21
(5,541 Views)
I figured that it will taka many days to debug that faulty data plugin, so I wrote my own simplistic WFM reader, attached. It produces results identical to Tek  DataPluging in fraction of time.
Message 10 of 21
(5,514 Views)
