04-25-2019 06:51 AM
Hello Supporters,
I'm using 5k series Tekscope and trying to save hardcopy of Tekscope screen to PC. I ran the VI, where Tektronix posted their forum and it makes it to the visa read vi and then throws an error with code -1073807339. It looks to be a timeout error where nothing is being sent back. When I ran the VI scope is generating a capture png file by itself, but LabVIEW thrown timeout error.
Even though I was tried many SCPI commands where I found in forum, but I couldn't achieve the result yet (Every commands gives me rapid timeout error).
Is anybody have a solution for this?
As shown below image codes are found it in Tektronix forum(It's not working);
Solved! Go to Solution.
04-25-2019 09:23 AM
I assume you have turned on tracing and observed your code execute. I will also assume that the error occurs at the VISA.READ command.
Have you read the manual for the hardcopy command? I would assume it would take some time to write to disk, so I would add a delay between the ":HARDCopy STARt;" cmd and the ":READFILE" cmd.
Also the default VISA timeout is 2 seconds, depending on how large of a file you are transferring, it might be running into that limit. Try adjusting the timeout. (VISA Pallet -> Advanced -> VISA Property)
04-25-2019 09:48 AM
You should really attach your code not post picture of code. It makes it easier to get help.
In picture 1 the timeout is only 5000ms, why not set it to something much, much longer? 300,000ms? Its a timeout (maximum wait time before instrument throws an error), so setting it to a very long time shouldn't slow things down.
In picture #2 there is no timeout set, so its likely 1000ms (1s), so why not implement the timeout from image #1 in image #2 and set it to a longer time and see if things work?
Craig
04-25-2019 11:42 PM
Here is my code! Rescue from timeout(Read VISA) error.
04-29-2019 12:01 AM
Damn! I found solution by myself, here is that.
