Talking to Fireberd 6000A 8000 in labview
By asynch, do you mean Serial/RS-232? The only advantage is that it is cheaper. I believe you would have to make some simple mods to add serial support so that will offset some of the cost savings.
Message 11 of 14
(1,111 Views)
Yes I was referring to the Serial/RS-232 interface.  Is the performance the same between RS-232 and GPIB?  Are there any known issues with one or the other?
Message 12 of 14
(1,103 Views)
No, of course the performance is not the same. You should be familiar with the basics of both types of communication. A serial connection might have 115k rate and a standard 488.2 connection is 1MB.
Message 13 of 14
(1,099 Views)
Have you tried to add a CTL + C (^C) string to the initial command?
I found that the FireBERD 6000 does not communicate over RS232 until the ^C is entered. Even using HyperTerminal.
I found however that I am unable to get results from the results command via LabVIEW VISA but I can get results from HyperTerminal. Command; RESULTS? DATE returns nothing from the VISA Read but does over HyperTerminal.
Anyone find a solution to get results over Serail RS232?
Message 14 of 14
(1,013 Views)
