10-13-2021 11:52 AM
Hello
I'm trying to follow the steps from this tutorial:
https://learn.ni.com/learn/article/getting-started-with-compactrio-hardware-and-labview#TARGET_5
However, when i'm going into the VI the channels are not well configured and i have no chance of setting the outputs like the video is showing because i can't install DAQmx add-ons in cRIO.
Someone have an idea why this is happening?
This is the software installed (in MAX):
This is the Devices and Interfaces (in MAX):
I have LV2019 and DAQmx 2019 installed via NI Package Manager.
Thanks in advance.
10-13-2021 12:05 PM
Maybe i have to use another cRio? Like 9053?
10-13-2021 12:39 PM
that is quite an old cRIO you have there, running VxWorks as OS and a 400 Mhz Power PC CPU. This is not compatible with DAQmx.
DAQmx is a relatively new feature on compactRIOs.
Regards, Jens
10-14-2021 04:21 AM
Hello Jens
I will change cRIO 9076 for cRIO 9053.
