I have a table that I am using to get user input.
The table has a certain maximum size that is displayed to the user.
(Ie 3 rows by 10 columns + row column headers).
I turned off all scroll bars since more than 30 entries is not allowed.
The problem is this :
If the user enters text and then presses the CR, the focus goes to the
cell below the current cell. This is fine unless the current cell is in
the bottom row. In this case the whole row moves up exposing a row
that I do not wish to be seen / modified. And no way to get back
since there are no scroll bars.
Conversely, if the TAB is used it will go through all the visible cells
and then return to the top left cell.
Any ideas ? BTW, I am using Solaris so the solution must be
G or
CIN.
Thanks, Kevin Kent
____________________________
My job is so secret, *I* don't even know what I am doing.
[See first answer for additional information]
