08-16-2011 12:33 AM
I want to create a Tab control with 2 pages, in each page there are 2 buttons - "OK" and "Cancel".
If on Page1, "OK" is clicked, Page2 will be disable and greyed, until "Cancel" is clicked. And vice-versa for Page2 buttons.
How to do this?
Thanks in advance...
08-16-2011 01:48 AM
08-16-2011 02:05 AM
Page Disable See here
08-16-2011 02:26 AM
Hi Splee,
Please view the attached vi, I believe it's doing what you've asked. You can invoke properties using property node in order to change the value of variables.
08-16-2011 02:58 AM
This is an easy way to do it!
Paul
08-16-2011 03:05 AM
Hi Splee,
Hi Simply_me check your Vi will it really works. To make this VI in working condition you have to do some more coding in your code.
Check your page selection technique.
Hi Splee,
First you have to find out on which Tab Page user clicking the buttons, the all operations you have to do on other page.
Once your page is disable you can't access the controls of that page. As Geeta says make a code using event structure with Tab Control property and invoke nodes.
You have to do some coding to achieve your requirements.
Thanks and Regards
Himanshu Goyal
