08-01-2019 03:57 AM
But guys as we say, if we find the solution for the answer eventually we end up finding another problem.
I have some buttons in each tab. I want to access these buttons with enter key. Like example, since I can change tabs with keys, ill go to second tab by pressing say '2' and FP tab will be changed to 2nd tab and then i press enter and when i press enter i want the button in the second tab to be activated or toggled. similarly then i go to 3rd tab and press enter to activate or toggle button in the third tab.
I have been trying this but couldn't implement properly.
Thanks and Regards
Baig
08-01-2019 05:44 AM
08-01-2019 05:47 AM
hi GerdW
can you please elaborate
thanks and regards
08-01-2019 07:11 AM
Work with the Key Down? event to see if you have the Enter key pressed.
When you do, use the current value of the tab selector to determine which tab page is open.
Use that to drive a case structure where you will determine which button is meant to be pressed. If those buttons are associated with the event structure, you can wire a true to a Value (signalling) property node of that button. That will queue up an event that the button was pressed just as if you had manually clicked on it.
08-01-2019 07:16 AM
Hi mabaig,
Wire the tab terminal to a case structure selector. In the cases you can send the "ENTER" action to any "button" you like to…
08-02-2019 01:11 AM
greetings
I tried this and it worked .. well but not the way i needed. It isnt failing completely. In my VI, I have subvi that has global variable in it and I am monitoring this global variable in my main VI FP as progress indicator. This is in the event structure (handled by value change of a button) and then I did what you said, took the case structure and gave the enter key scan value to trigger that button then it does activate the event case always but the global variable is not getting updated(only showing final value when it is supposed to increase linearly). when i manually click button it is updating properly
What should be the mechanical action of the button
Have any idea where its getting messed up with global veriable
NOTE: I am using Property Node value(signaling) to trigger event structure
NOTE: Global Variable is updating linearly only when I click the button then I press enter. For proper updating again I have to click manually otherwise pressing enter shows direct final value
Thanks and Regards
Baig
08-02-2019 01:18 AM
Hi mabaig,
So you have some VIs and some bugs in those VIs. As soon as you attach them we will be able to debug with you - until then you need to debug on your own…
Why do you need a global variable, being a possible source of race conditions? Why not use a shift register in your main event handling loop to store the current tab page?
08-02-2019 07:06 AM
Hi GerdW
Sure that would be great help but I couldn't attach now. I have the vi files in my office PC not the one I am using for forums.
I am using two global variables in this application. I am downloading some HEX data to a microcontroller so here, I needed to check handshake after each byte , and to monitor the activity I am using slider as a progress bar connected no number of iterations of the subvi loop where data is being downloading.
Another Global variable I am using to update the total length of the selected Hex code from sub vi to main vi for max value of the progress bar(slider).
If you have any better suggestions it would be appriciated
thanks and Regards
Baig
08-02-2019 07:23 AM
That description doesn't clarify where the tab control and all those buttons come into play.
So we can wait until you get back to the office PC to have access to the files you can upload to the forums.
08-02-2019 11:30 PM
Hi
Its working fine. After placing these global variables, I actually needed to reinitialise them at the end so that in the next operation these global variable values could be change to appropriate code file length.
Thanks & Regards.
Baig
