11-29-2019 05:24 AM
It works perfect!! Thank you so much for explaining me everything! I am very grateful with all your help!
Best regards!
11-29-2019 06:05 AM
Hola!
Como puedo hacer para que cuando meta un string cada caracter del string me active su correspondiente boton en un array de booleanos?
Gracias!
11-29-2019 06:32 AM
Look into the event structure.
Either catch the key down and key repeat events, or use the value change event (set the string to "update while typing").
11-29-2019 06:42 AM
I think this merged post is actually a different question...
