Hi everybody, I am having issues producing an output TTL signal from the module.
I can't seem to figure out what is causing the problem. I am currently using the cRIO-9042 with an NI9401 module. The module is under Real-Time Scan Resources and I have configured the module properties to output for DIO7:4. When I put a True signal to turn on the output, it stills remain False.
Any help or advice on this particular issue will be greatly appreciated! This problem has been hindering my progress. Thank you!
