Johannes Niess wrote:
>"Brian" writes:>>> I am wondering how some of the
O'Scope controls were emulated. For example:>> In the>> tkds30xx Configure
Chan Characteristics.vi there is a control that takes>> a vertical slide
and>> that has text labels active and is able to output a specific double
value>> of either (50.0 or>> 1000000.0). The values do not follow the conventional
'Enumerated' type>> definitions that are>> defined in both the G Programming
Labview documentation and vertical slider>> controls in the>> software itself.
Basically you can not get there from here!>> >> This knowledge would be
extremely helpful to me in order to produce similiar>> vertical slider>>
outputs that do not need to be incorporated
in a case to get specific double>>
output results.>> >> Thank you in advance.>>Brian,>>these controls might
be doubles/singles with range checking enabled,>e.g:>>min value= 50.0>max
value=1000000.0>step size= 999950.0>coerce values>>HTH>>Johannes Niess
Johannes,
Thank you for the info but I think this is a custom slider control. Doing
what you specify will
be reset once you swich the slider to incorporate Text Labels. By doing
that you in effect make your values enumerated starting from 0 on upward.
The slider control I have referred to has somewhat been converted to actually
output the value of either 50.0 or 1000000.0 with the slider utilizing the
Text Labels feature.
bri
