TDS3034 Scope acquire voltage level problem
Hello All,
I currently need the TDS3034 to measure the voltage only (no pulses). I have sucessfully used the Labview Instrument Driver for PWMs.  I cannot figure out how to setup the vis for a steady voltage level measure, all the exisiting code relies on triggers etc. I keep getting a "low signal level" popup. I think I should use the Software Trigger vi but dont know how to set it up alongside the other vis.
Advice Appreciated
Thanks Chris
(2,870 Views)
Specifically, what measurement are you telling the scope to do?  Sound like you want "High".  Also check your measurement references.  Make sure they are set to percentages, not absolute voltages.
(2,868 Views)
Hello crossrulz,
If I put continuous 3.3 volts into the scope I need to measure the 3.3 volts, I want to use the scope as a DMM for this measurement. The problem for me is the TDS 3034 scope examples shipped with labview contain vis that set the scope up to trigger on a leading edge. They assume the incoming signal has a voltage level shift and will trigger when a state change occurs.
I need to obtain the voltage level (say Vaverage) of a continuous voltage level applied to the scope. I imagine this would involve:
scope init
auto configure
software trigger
get the values
do maths
get results
release scope resource.
I dont see how to apply the vis available to achieve this.
Regards
Chris
(2,849 Views)
Just quickly thinking through it, I would just do this:
(2,841 Views)
