12-14-2006 12:42 PM
12-15-2006 05:33 AM
Hi Timpy,
Can you post some vi's that show this behaviour?
Hannah
12-15-2006 09:47 AM
Hi Hannah
A vi for point 2 I can attach easily, the other first one will take a little more time. I've stuck instructions into the vi for running it but I very much doubt you'll need them.
Thanks for the reply.
Cheers
12-15-2006 12:06 PM - edited 12-15-2006 12:06 PM
Message Edited by Jarrod S. on 12-15-2006 12:07 PM
12-18-2006 11:11 AM
12-28-2006 03:54 PM
I just spent 2 hours trying to figure out why my data wouldn't come out right, even though I did the same steps as in a DAQMX example. I finally found this thread on the forum.
This transpose problem needs to get fixed ASAP. TDMS is for high-speed streaming, and I'm sure many of us cannot afford the performance hit taken by using the workaround. A Transpose Data boolean on the TDMS Write and Read functions would be much appreciated, if it will improve performance over doing it in the app.
02-07-2007 08:31 AM
LabVIEW representatives have been pressing how much better/faster they are. I liked the data and database technology of the files. My old files are text. So I had decided to convert my old data to TDMS and combine the environment files into one (environment files are the properties and sensor information of the old text files). So I built a nice user interface to make it possible for the user to make decisions and then write the file. After twelve hours wasted of my life, I find this one lone thread explaining the workaround. That is a fast workaround BTW. And was that the only problem? NOOOOOOOOOOOOOOOOO! I also had the pleasure of experiencing another bug in the same VI at the same time. You know the all confusing sub array of array thing. I like that one. So lets recap-2 bugs on first attempt. My first thought was "were these even tested?".
Sorry about my rambling. I think I broke a couple of blood blisters and now I'm potential for stroke.
All being said, WHEN you fix this crap, they WILL be the next best thing to sliced bread!!
Any more bugs I should know about?
Chris Co
