Within MATLAB 2018b, I'm attempting to use the TDMS C DLL to read images from a TDMS file that are stored as an array uint16's (data type 0x6). My first attempt at this was as follows:
inds = startInd:(startInd + numImages - 1);
pImages = libpointer('uint16Ptr', zeros(1, numel(inds)*imageHeight*imageWidth));
status = calllib(libName, 'DDC_GetDataValues', channel.ID(groupInd, channelInd), (startInd-1)*imageHeight*imageWidth, numel(inds)*imageHeight*imageWidth-1, pImages);
However, this causes MATLAB to crash. I tried to dig into the problem by requesting the datatype for this channel using:
[status, dataType] = calllib(libName, 'DDC_GetDataType', channel.ID(groupInd, channelInd), 0);
and dataType returns 'DDC_Double', which corresponds to datatype 0xA. I've confirmed with my TDMS File Viewer that 'NI_DataType' for this channel is indeed set to 0x6 (uint16):
But for some reason, the C DLL thinks that it is a double. If I modify the above snippet of code to initialize libpointer as a 'doublePtr', then my images are read correctly:
pImages = libpointer('doublePtr', zeros(1, numel(inds)*imageHeight*imageWidth));
Can anyone help me understand what is going on here? I've noticed that within the C header file that comes with the DLL (nilibddc_m.h), it does not appear to support uint16 datatypes:
typedef enum {
DDC_UInt8 = 5, // unsigned char
DDC_Int16 = 2, // short
DDC_Int32 = 3, // int
DDC_Float = 9, // float
DDC_Double = 10, // double
DDC_String = 23, // string
DDC_Timestamp = 30, // timestamp (Year/Month/Day/Hour/Minute/Second/Millisecond components)
} DDCDataType;
If there is no support for uint16 data types, then I would expect it to crash or return an error, rather than declare it to be a double. Any help or insight would be much appreciated.
Thank you,
Erin
