10-23-2018 03:12 AM
Hi guys,
I have a problem with tcp/ip connection, it works very slowly and I cannot find the source of my problem.
I attached screen from wireshark.
10.93.1.105 - server
10.93.1.244 - client
As you can see in the pictures, when I force data to send, server responses pretty fast. But receving data in Labview works very slow(the next data is send when previous is received)
So I assume it shouldnt take more than 200ms. After 5 mins since start it takes like 1s to receive answer, after 15mins it takes like 4-5s....
Is there any leakage or I should clean buffer or what?
In read_buffer.vi you have got full structure. I have header - forces server to send size of data in the buffer, when this size is different that 0 starts to read them.
I have verifed that in wireshark, microcontroller(server) sends everything correctly, and correct size.
I attached 3 files - these show my problem.
thank you for any advices.
10-23-2018 04:26 AM - edited 10-23-2018 04:27 AM
Hi Mirasoul,
Do you build big arrays? As you do in that Read VI with repeatedly using InsertIntoArray with allo those hidden controls/indicators?
That would explain such behaviour…
10-23-2018 04:50 AM
first of all thank you for answer.
there are lots of wait functions in your code: usually you don't need additional waits in server-client communication…
- meaningless in this software, it doesnt explain why it slows down in time.
you are reading/writing to a lot of property nodes, the can (potentially) slow down your VI…
- meaning less, there was not a big amount of data
- it could be it, but its not....
I send updated version. Still doesnt work correctly.
I removed all data collectors, but still wrong.
10-23-2018 05:38 AM - edited 10-23-2018 05:39 AM
Hi Mirasoul,
more suggestions:
- combine your 3 TCPWrite operations into just one by appending the 3 arrays into just one. No need for those tiny statemachines to send a request to your device.
- there still are waits in both loops: 30ms in the receiver loop, 25ms in the sender loop. What's that weird coupling between the loops using a value property of that summed up enum value?
- there's no error handling in your (main) VI: do you get any errors while running the VI?
10-23-2018 06:00 AM
Unfortunately, not possible. These are procedures for Microcontroler bootloader(just simplified, to show an idea of work). So it has be in this way. ...->adress->feedback->length->feedback->data->feedback->address->...
-updated in the attached version
-none
10-23-2018 06:09 AM
Hi Mirasoul,
So why do you separate sending and receiving into 2 loops?
Why not implement a proper state machine to exactly follow those steps?
10-23-2018 10:50 AM
You can try disabling the Nagle algorithm. This will force the TCP to write the data as soon as it gets it.
01-04-2019 09:38 AM - edited 01-04-2019 09:40 AM
Where did you get this VI? It looks suspiciously like a VI that I believe to have posted somewhere around fall of last year somewhere but I can't find the post where I did that for the life of me. And I'm afraid that at least the Mac implementation might not be quite right though haven't tested that yet.
01-05-2019 06:57 AM
Doesnt matter where he got it.
According to main subject.
I used queues to separate transfer layers and it solved problem. It was newbie problem:).
01-06-2019 02:36 PM
That's easy to say if you aren't the author.
