05-10-2018 11:59 AM
Hello, I´m using an ESP8266 WIFI module as a client (controlled by a PIC18F2550), and a Timed Loop, where first a TCP Write sends "x" bytes to the module and then a TCP Read receives "y" bytes from the module. It works. The problem is that for the application, I need 10ms for each iteration of the Timed loop.
The PIC sends the bytes (through the module) 1ms later than it receives from LabVIEW. And the operation (Write - Read) takes less than 2ms. But despite the timed loop is set to 10ms, each iteration takes 30ms.
Do you know why?. Is there a way to make the TCP Write and TCP Read VI's work faster?
Here is the code. Before the timed loop, a TCP listen, wait for the connection, once the module and LabVIEW are connected, it goes to the loop.
Thanks.
05-10-2018 01:01 PM
05-10-2018 02:42 PM - edited 05-10-2018 02:43 PM
Hi Hector,
Do you know why?
Because of all those bended wires? The data will flow faster through straight wires! (Just joking…)
The Rube-Goldberg constructs in your code also doesn't help to speed up the loop.
It doesn't make sense to put a non-deterministic operation like TCP communication into a deterministic loop like the TWL!
Use a standard while loop and work with the timeouts of the TCP operation to read and write data as fast as possible…
05-14-2018 03:37 PM
Hi, I tried disabling the Nagle algorithm but nothing happen. Without the TCP Read, the loop goes ok, each 10ms. It seems like the problem is in the TCP Read.
05-16-2018 11:07 AM - edited 05-16-2018 11:07 AM
Nagle would only affect the write; not the read (unless your PIC uses the same algorithm). Like GerdW said, TCP is non-deterministic. Don't expect it fit your timing constraints.
