01-08-2018 06:07 AM
If you wanted to transfer the values of Numeric 1, Numeric 2, Numeric 3, Numeric 4 & Numeric 5 using the method discussed above you would do something like this
Hope this helps
Steve
01-08-2018 06:11 AM
I do this, but when I want to read in server and I use Unflatten From String and unbundle I obtain an indicator not a control.
01-08-2018 06:32 AM
Maybe, I would have to do a new tcp communication changing the roles?
01-08-2018 06:49 AM
cristina.lopez wrote:I do this, but when I want to read in server and I use Unflatten From String and unbundle I obtain an indicator not a control.
Use a Local Variable to update a control. Note that is it usually really bad UI to have the code manipulating controls that the user should be using.
01-08-2018 07:13 AM
Hi Christina
It is probably best to think about it as data rather than a Control or Indicator. I agree with crossrulz, firstly question why you need to update controls in your Server. Could you change your Server to better accept the data being received (is there a better way to do things)? If not then use a local variable to update your controls.
Steve
01-08-2018 08:52 AM
My goal is following:
I have three .vi one in FPGA , one in Host-target and one in Host-computer and I want handle all program from the computer, and in this .vi i want to change the control for they'll change in target (host and fpga), so that, I want see the controls and indicators in conputer (server)
01-08-2018 08:57 AM
01-08-2018 09:11 AM
Hi Christina
GerdW is correct LabVIEW gives you the best possible start and does not expect you to start from the beginning each time. Also there is plenty of information on ni.com, check this out as an example.
Steve
