TCP TRANSFER DATA
If you wanted to transfer the values of Numeric 1, Numeric 2, Numeric 3, Numeric 4 & Numeric 5 using the method discussed above you would do something like this
Hope this helps
Steve
Message 11 of 18
(708 Views)
I do this, but when I want to read in server and I use Unflatten From String and unbundle I obtain an indicator not a control.
Message 12 of 18
(705 Views)
Maybe, I would have to do a new tcp communication changing the roles?
Message 13 of 18
(694 Views)
Use a Local Variable to update a control.  Note that is it usually really bad UI to have the code manipulating controls that the user should be using.
GCentral
Message 14 of 18
(689 Views)
Hi Christina
It is probably best to think about it as data rather than a Control or Indicator.  I agree with crossrulz,  firstly question why you need to update controls in your Server.  Could you change your Server to better accept the data being received (is there a better way to do things)?   If not then use a local variable to update your controls.
Steve
Message 15 of 18
(682 Views)
My goal is following:
I have three .vi  one in FPGA , one in Host-target and one in Host-computer and I want handle all program from the computer, and in this .vi i want to change the control for they'll change in target (host and fpga), so that, I want see the controls and indicators in conputer (server)
Message 16 of 18
(676 Views)
Hi Cristina,
did you create an example project for your PC host/ RT host/ FPGA system?
LabVIEW comes with such examples - the communication is explained in them quite well…
Message 17 of 18
(673 Views)
Hi Christina
GerdW is correct LabVIEW gives you the best possible start and does not expect you to start from the beginning each time.  Also there is plenty of information on ni.com, check this out as an example.
Steve
Message 18 of 18
(668 Views)
