06-20-2018 06:43 AM
I have two Rios, which I eventually intend to expand to around 8 or so.
My question is, my server and client work without any issues when running, and will run for long periods of time with no issues. If I disconnect the Ethernet from one, and then reconnect, they will find each other again. Now both are Servers, and both are Clients for each other.
However, my issue comes up when the Rio restarts. When it restarts, they tend not to reconnect with each other on restart. The device that restarts is able to send data, but not receive data. Does anyone have any suggestions as to why this may be and what I can do to resolve this?
06-21-2018 11:19 AM
I'd be interested to know whether your sbRIOs are using static or dynamic addressing. If they are using dynamic addressing, they could be receiving a different IP address each time they reboot, potentially causing packets to be sent to the wrong address. They therefore would not receive data.
Getting more information on how you are implementing the servers would also be valuable.
06-28-2018 03:47 AM
Static addressing.
I think I worded it poorly. It's not restarting that's causing the issue. It works fine with the restarting part.
When power is lost, and then you start it up again, it's then that it can't connect.
06-29-2018 12:07 PM
Thank you for the addressing method clarification. I have a couple other clarifying questions:
