취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
TCP/IP fails but HTTP works. Why?
Hi all,
Bit of a newbie when it comes to TCP/IP and HTTP. I am trying to talk to a SoMat eDAQ lite and stream data off it by making the appropriate call as shown in the pictures that are attached.
This seems to work fine if I use the HTTP subVI and saves a file to disk. I want to get access to the data so want to use the TCP/IP to get the data in chunks but it throws error 56 on the read TCP/IP subVI call.
Any advice?
Phil
모두 다운로드
0 포인트
1/2 메시지
2,522 조회수
@therealkilkenny wrote:
Hi all,
Any advice?
Phil
check your firewall
also check this thread and links:
error 56 thread
Error 56 tcp connection
Error 56 Occurred at TCP Open
0 포인트
2/2 메시지
2,515 조회수
