TCP/IP communication over SSL on RIO
I'm looking for some hints how to implement TCP/IP communication over SSL in LabVIEW on MyRIO, CompactRIO etc.
I was thinging about using .NET asseblies for TCP connection but I'm afraid it will not work on RIO.
Any suggestions?
Thanks in advance.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,646 Views)
It looks like OpenSSL is already included on RIOs: https://decibel.ni.com/content/thread/46257
I believe you won't be able to achieve what you want with simple TCP/IP VIs, as SSL is an additional abstraction layer above TCP. It seems like others have had the same problem before, and it's not officially supported: http://forums.ni.com/t5/LabVIEW/TCP-IP-using-SSL/td-p/2583817
You're going to have to implement a wrapper library to make calls to OpenSSL.
(3,598 Views)
