02-03-2011 04:32 PM
TCP 2106 windows CE
DAQ MX base
I recently recieved some new TCP 2106 and did the normal instalation of daqmx base and visa and the touch panels wont run my software. (daq mx base utilities 'Windows CE for ARM Driver Installation (TPC 2x06)' )
What esle is missing on this touch panel. It runs LabView programs fine, but as soon as I use a DAQ MX base in my program it throws the two errors below:
If trying to execute the file on the device i recieve this error:
"Cannot find 'application name' (or one of its components). Make sure the path and filename are correct and all the required libraries are available."
http://forums.ni.com/t5/LabVIEW/Pocket-PC-application-fails-to-run-missing-libraries/td-p/765551
And when trying to run from my host computer i recieve
Error - Unable to run the application on the remote device. Create Process failed with error code = 126
http://digital.ni.com/public.nsf/allkb/FF1C8C4D6E7126EC862574EB0068E9C8
I ran all these commands to check for the libraries, I also looked for them manualy
pget \Windows\aygshell.dll c:\temp\aygshell.dll
pget \Windows\commctrl.dll c:\temp\commctrl.dll
pget \Windows\commdlg.dll c:\temp\commdlg.dll
pget \Windows\COREDLL.dll c:\temp\COREDLL.dll
pget \Windows\ole32.dll c:\temp\ole32.dll
pget \Windows\WINSOCK.dll c:\temp\WINSOCK.dll
pget \Windows\WS2.dll c:\temp\WS2.dll
Everytime I recieved this message, insuring that the files are there.
Connecting to Windows CE...Success
Unable to open Windows CE file
Thank you in advance for any insight.
Never had this problem before, very frustrating!
02-04-2011 11:51 AM - edited 02-04-2011 11:58 AM
Hi Laptopolus,
Touchpanels are definitely an area where our knowledgebase can be lacking, and this seems like a strange issue. I would suggest finishing the instructions in that KB and reinstalling both DAQmx Base and visa. Let me know if you are still getting the problem after you reinstall.
