TCA9548A I2C multiplexer with Ni-8452
Hi there, I have a number of SHT85 sensors with me. I am able to get the humidity and temperature data from one sensor using the NI - 8452 I2C interface. Each sensor has 0x44 as the I2C address and it requires 2 other I2C commands to get the data from it. I have activated the internal pull-ups at the logical voltage of 3.3V.
Now i want to setup at least 2 SHT85 sensors with the I2C interface in the NI-8452. Since all the sensors have the same address, i want to use the TCA9548A I2C multiplexer on the single I2C bus in the interface, so that i get the humidity and temperature data from both the sensors. This multiplexer has an address of 0x70 and 8 channels (0 - 7).
To start with i have just connected only one SHT85 sensor at channel 0. I have simply changed the address in the I2C configuration and added 2 extra I2C wirte blocks with idea of selecting the I2C multiplexer channel which had the sensor connected. I have retained the I2C write block which calls the SHT sensor (with address 0x44) follwoed by the other I2C commands to get the data from it.
On execution, there were no errors flagged while the program was running but i was not getting any data from the sensor via the multiplexer. Please find the attached VI and please point out what am i missing.
Message 1 of 11
(481 Views)
Your main problem seems to be that you are not understanding that the Address property sets the address that the NI-8452 will attempt to communicate with when an interaction is done. You need to actively set that property when you want to change which I2C device you want to talk with.
Message 2 of 11
(434 Views)
Thanks for the pointer, I will try this changes suggested.
Correct me if i have got this wrong - by following the method you have suggested, i simply need to change the data meant for selecting the channel at 0x70. And after that it is simply commanding the SHT85 sensor connected at that channel.
Message 3 of 11
(423 Views)
That is correct.
Message 4 of 11
(396 Views)
I was able to read the sensor data at channel 0 of the multiplexer. I will connect the other sensors to it and try reading from them as well. For this, i still can simulateneuosly select the other channels from the I2C configuration for 0x70, right?
Message 5 of 11
(378 Views)
What I do is update the Address property to whatever it is you are trying to talk with before each interaction. I'm not sure the device can multiple configurations as I have not tried doing that.
Message 6 of 11
(373 Views)
i have implemented concurrent channel selection in the mux and i am getting data from both. But now its like displaying data from channel 0 very briefly and showing the data at channel 2. I am not sure if i am getting the correct data from the sensors. How do i select all the channels efficiently?
Message 7 of 11
(337 Views)
i got the solution now. since i am using the same I2C lines, i was not giving enough time for the first sensor to display its value and was letting the other one to show its value. Thanks for the help
Message 8 of 11
(333 Views)
The simple solution there is to just use the error wires to serialize communications. This will let data flow handle the synchronization instead of arbitrary waits.
Message 9 of 11
(324 Views)
I dont understand! what do you mean by 'just use the error wires to serialize communications'? By serializing you mean, selecting the next channel after every 100ms and closing the I2C bus outside the loop ? If not then how do i proceed coz when i do this, i get to see a delayed response for sensor 2 along with the current data for sensor 1.
Before making an attempt, i also realised that whatever data i was getting was not from both the sensors, it was just data coming from only the first selected sensor, its never giving the data for the second sensor. Can you please tell what am i missing out
Message 10 of 11
(294 Views)
