System timout when reading data from cRIO9073
Hi
I have a system with cRIO-9073 and all the logging data from measurements are saved in "c:\Data". Now I want to read the data out but whatever I've tried it always ends up with a connection timeout. I've tried the FTP, HTTP and also direct RT-Program in the cRIO.
The folder can have 3056 saperated files, which I can use the folder Info VI to know. However, listing the names of the files can lead to a timeout.
Wilbur
Message 1 of 20
(4,559 Views)
Hello wilburwu,
could you describe your problem a little bit better. Which VI's are you using and how is your error produced?
Maybe a screenshot can help me to understand your request better.
Stefan
Message 2 of 20
(4,543 Views)
All right,
I'll tell the story:
1. Start the MAX and use the "data transfer" on the CRIO
2. in the prompt windows I'll leave the FTP login as default:
3. After Login I'll wait for the list of files:
4. after maybe 1 minute...here comes the error 66!! The FTP is canceled and I cannot get the files from the RIO. And I promise that the cable was NOT defect and the cRIO is as always running.
Message 3 of 20
(4,535 Views)
And by the way the NI-RIO 3.5.0 June 2010 is installed on the CompactRIO
Message 4 of 20
(4,532 Views)
@wilburwu wrote:
Hi
Wilbur
I have the same problems with the NI Internet VI's.
Those VI's are in desperate need of a connection/transfer/command timeout connector.
I think you should do a bug report and file a Service Request, by calling or emailing NI.
Another piece of poorly tested NI toolkits. Smiley Sad
Probably you have to use the more advanced FTP VI's and perhaps even modify those to accept command/transfer timeouts.
Br,
/Roger
Message 5 of 20
(4,529 Views)
Well, finally I have clean up one folder, which contains 3056 files. After that I have the normal FTP connection with the cRIO.
However this is not quite usual as a user of the CompactRIO system. This makes the file transfer really complicated if I have the measurement files saved on the cRIO itself. Shall I post this as a known issue? when yes, where??
By the way, there is no USB on the 9073!
Message 6 of 20
(4,510 Views)
I have seen the same issue when using a 9074 and accessing via a Windows FTP session.  Large file counts are a major problem.  In one case I had to actually reformat the cRIO.  I'm now using lots of subdirectories to help get around the problem.
Message 7 of 20
(4,503 Views)
The classic LV hackery & trickery to work around problems. That sucks. Smiley Frustrated
The best is to file a bug report, call NI with the details. That way we can get our tools in better shape once the issues are floating around in NI's IT systems.
Go to:
http://ni.com/support
And help yourself.
Br,
/Roger
Message 8 of 20
(4,497 Views)
Rogerlsaksson wrote:
The classic LV hackery & trickery to work around problems. That sucks. :smileyfrustrated:
Go to:
And help yourself.
It's most likely a limitation of the FTP server, not a LV bug.  Many pure FTP servers are limited to a max of 2000 files in a directory.
Message 9 of 20
(4,482 Views)
I get timeout errors when I transfer large files as well.
Please, not so fast defending a poor FTP client implementation there.
Also, speculating about the virtues of the NI FTP server running on the cRIO is a bit off the mark, isn't it?
Whatever happens, it should not force users to reformat the device beacuse it is too many files in a folder.
Poorly tested, poorly implemented, frankly it sucks.
Br,
/Roger
Message 10 of 20
(4,478 Views)
