System exec rmdir doesn't work
You're right. The OpenG source code does do a much better job of deleting the files. It is still CPU intensive, but, that is probably the way it will have to be to delete a whole directory like this. Thank you all for your help. (Although, I'm still curious why the system exec and rmdir command didn't work.)
Thanks for showing me OpenG by the way. It looks to be a really comprehensive set of tools.
Message 11 of 15
(1,361 Views)
Yes, it is strange.
Did you capture the standard output and standard error for some clues?
Have you also tried e.g. "del /F /S /Q".
Message 12 of 15
(1,354 Views)
I put probes off of those inputs when I was executing the system exec VI, thinking there might be some sort of error message as well, but they both came back as empty. One thing I didn't do was connect up the error out from the system exec VI to a generic error handler; so it is possible that the VI was returning some sort of LabVIEW error.
Message 13 of 15
(1,352 Views)
System Exec does execute applications and command files like *.exe and *.com. However some commonly used command like dir or rmdir are not executable command files but commands internal to the command interpreter which is cmd.exe. To execute these internal commands you have to invoke cmd.exe first with System Exec.
In that case, the string you pass to System Exec is "cmd.exe /C rmdir [path]".
Message Edité par Jean-Pierre Drolet le 06-25-2005 09:39 AM
LabVIEW, C'est LabVIEW
Message 14 of 15
(1,344 Views)
Thanks for the information.
Message 15 of 15
(1,317 Views)
