System Configuration 'Find Hardware' can't see daqmx expert when built to EXE
Hi everyone!
I have a problem with System Configuration API not finding any DAQmx hardware when an application is built to EXE.
When I run the code from LabVIEW environment there is no problem, all my hardware (real and simulated) is discovered and listed. However when I run it from built application I get an error:
daqmx isn't listed by 'Get System Experts' VI from EXE.
I tried reinstalling DAQmx and System Configuration with no result.
LabVIEW v21
DAQmx v21.8
System Configuration v21.5
Thank you for help!
Message 1 of 8
(2,686 Views)
Same PC on which you run the LabVIEW program?
Rolf Kalbermatter  My Blog
Message 2 of 8
(2,650 Views)
Hi rolfk,
Yes, it's the same machine.
Message 3 of 8
(2,648 Views)
I've never used "Get System Experts".  To find attached DAQmx devices, I've always used something like the following to find specific or groups of devices -- this works identically (for me, anyway) in Development or Executable modes.  [I have, successfully, used the System call that looks for remote TCP/IP targets, very handy if there is a particular IP I want to use as a target for Network Streams -- such code also works find in Development and Executable modes].
Message 4 of 8
(2,640 Views)
Hi Bob,
Thank you for your suggestion!
Your solution indeed works well both in executable and in development modes. However I specifically used System Configuration API to check whether the device is present in the system. In my case (various cDAQ-9185 chassis, frequently disconnected/connected from the LAN) it is quite annoying to see the devices listed by DAQmx System property that are not present in the system. I can't find anything from DAQmx nodes that matches System Configuration's 'isPresent' property, but I may be missing something.
Message 5 of 8
(2,610 Views)
I don't have any issues with LabVIEW 2022 Q3, NI-DAQmx 2022 Q4 and NI-SystemConfig 2022 Q4.
https://tmesystems.net/
Message 6 of 8
(2,592 Views)
In my reply, I also said "I have, successfully, used the System call that looks for remote TCP/IP targets, very handy if there is a particular IP I want to use as a target for Network Streams -- such code also works find in Development and Executable modes", which is how I find the "connected RIOs".  For IMAQdx, there are similar calls that will list the available cameras if you are doing video stuff, and the list probably goes on ...
Message 7 of 8
(2,562 Views)
Hi ZYOng,
I've upgraded LabVIEW, NI-DAQmx and NI-SystemConfig to matching versions with you and still can't get it to work... Then I guess the problem is specific to my machine.
Message 8 of 8
(2,512 Views)
