I'm working on a project, where we present a stimulus, a predefined waveform, and we want to measure how well a user can use a device to follow the waveform. Two requirements for this device is that we want to show the stimulus as they would need to react to it, and we want to store all the data to a file, so it can be analyzed later. The problem is the stimulus signal needs to look randomly generated, so to minimize learning affects, to do this we combine a series of sine waves at different frequencies. Because of this I am having the following issue.
Basically, at the moment I am having problems importing a pre-generated waveform, and then showing both the stimulus and response waveforms on a Waveform Chart as time varies.
I generated the goal waveform in MATLAB, with the correct time and magnitude arrays. I was able to import the data and plot it in Labview, however, I can only plot the data in one graph not over a period of 15 second like I would like. Also, I can not plot the user generated signal on the same plot.
I tried to identify the problem as best I could but if you would like further clarification on anything described above I can try to elaborate more on what I'm struggling with.
Thanks for any help anyone gives.
Mike
