DAQ Cards being used: - PCI-1200 (2 DIO lines used for transmitting digital signals) - 6023E (2 DIO lines used for receiving digital signals)
Problem: I would like to send and receive digital data continuously at the same rate. I don't know if synchronization has to be done in software, or there can be some sort of trigger/clock signal to use between the two DAQ Cards. Please Help. Thanks
Try to look at RTSI. The PCI-1200 doesn't have that connector though. If you want, you can try to do it by software. If you want high-speed synchronisation, you HAVE to use RTSI, but then you have to look at other cards. PLease call your local NI Office for more information... they won't hurt you!
Koen Hoogstoel National Instruments Belgium
Antony Wangsanata wrote in message news:387e8f41@newsgroups.ni.com... > > DAQ Cards being used: > - PCI-1200 (2 DIO lines used for transmitting digital signals) > - 6023E (2 DIO lines used for receiving digital signals) > > Problem: > I would like to send and receive digital data continuously at the same rate. > I don't know if synchronization has to be done in software, or there can > be some sort of trigger/clock signal to use between the two DAQ Cards. > Please Help. Thanks > >
