08-21-2006 09:05 AM
08-22-2006 06:09 PM
Hi Joe,
Check the security setting for the Symantec Anti-virus to allow file access. Meanwhile do you have LabVIEW 7.1 development environment or are you just running an executable created in LabVIEW 7.1 on the machine with the runtime engine?. Need more information on the LabVIEW executable you are running.
Tunde.
08-22-2006 08:26 PM
08-23-2006 06:11 PM
Hi Joe,
Try to run the executable on another computer with Symantec. I will also need more information on the executable especially the file operations to further troubleshoot this issue.
Tunde.
08-25-2006 02:11 PM
08-25-2006 02:21 PM
08-28-2006 06:59 PM
Hi Joe,
This might be a network issue. Can you access this file location through Start->Run in windows ? Are you using a "Relative file path" function in the VI?
I will suggest you post the LabVIEW program.
Tunde A.
Applications Engineer, National Instruments.
08-29-2006 11:14 AM
