Switching off numbering of pins in the connector pane
I have just noticed in Labview and Teststand that every VI I have created in a test program now has each pin named in the connector pane/prototype window of TestStand with a number to the right hand side of it in square brackets (please see attached picure) and also the VI Name itself has been asigned a number. This is now happening across ALL of my VI's in every project so is something global. I was wondering if someone knew how to switch off this numbering because it has only just appeared whilst I was editing a vi. It may be that i have inadvertantly switched something on. I seem to remeber from my Labview course that this is an optional thing and can be switched off but cant rmember how.
regards
John
(3,220 Views)
In the options dialog, it should be under the VI scripting area in the VI Server page. I think there's a specific checkbox for that behavior.
___________________
Try to take over the world!
(3,200 Views)
Many Thanks, that did the trick. Not important just annoying that it suddenly there.
Much obliged
John
(3,186 Views)
