Hi all,
I need to configure two different switch session in the same VI. I want to use different multiplexing channel for different measurements with DMM PXI 4065. I the same VI i'm running two identical sequences in which i configure switch channel and DMM measurements setup. However the two measurements never work together (only one works porperly every time i run the VI)
HAve you suggestion?
Thank you
