Swapping x and y axis in intensity graph
I have a VI that I've been using to display a graph of force v time data coming from a load cell. I've been using it for a couple months now with minimal issues, but today I tried to run the program and it is not doing anything. Normally I press run, then "Zero Data" and the line displays on the graph. I've attached the VI. Any help would be appreciated as I need to continue tests ASAP.
(2,429 Views)
First thing, what does this have to do with the subject of your message? Second, I don't see any error handling in there, can you probe the error line and see if any of your subVIs, in particular LDS_setup or DAQ Assistant, are returning errors?
(2,422 Views)
