04-16-2009 12:06 PM
oh..i c...
Labview makes life so easy...
thank you for your help agian
04-16-2009 06:43 PM
hi kristen, sorry...again..
i created an example of 1 file image for OCR from the example you give me.
I think I implemented it.
I was not able to decode the object. i got an ??L7?????????
do you know why?
04-17-2009 08:33 PM
Hi krispiekream,
Make sure the green ROI is accurate. Also, it might help to use the OCR Training Interface to help the OCR algorithm learn the characters better. The OCR Training Interface can be found by going to Start >> Programs >> National Instruments >> Vision >> OCR Training. I hope this helps!
Kristen H.
04-18-2009 02:39 PM
Hi
I have made a PC controlled RF robot operated at 434 Mhz using parallel port. The circuit having only four channels in order to control two motors in both direction. But now I want to attach a camera in the robot which acts as eyes for my robot and my robot can see the enviorment and transfer exactly to the labview wirelessly and so that I can choose the best path for its movement.
So please suggest me where to began i.e type of camera required and how should it be programmed.
Thanks in Advance.
Regards
Gaurav Sharma
04-18-2009 08:05 PM
Gauruv,
Your question is unrelated to the original thread. You should post a new message thread with your question.
04-20-2009 04:39 PM - edited 04-20-2009 04:40 PM
Hi Kristen, I am back on this project agian..
okay..here is what i have..
I dont know where I did wrong to get that error.
04-21-2009 09:16 AM
Hi krispiekream,
I assume you were trying to run the OCR example when this error occured? Were you able to run it before? If so, did anything change between being able to run it and the error occuring? Can you check Measurement & Automation Explorer for LV RunTime Engines?
Kristen H.
04-21-2009 10:48 AM
no, i am trying to using OCR training and it was missing labview runtime engine.
It is working now. I am trying to get familiar with the OCR training interface.
Thanks!
04-21-2009 11:19 AM
Kristen,
the OCR training is very cool.
But just in case my professor asked how did I do it.
Do you know where I can find information on how NI uses the OCR algorithm?
04-22-2009 01:21 PM
Hi krispiekream!
The best documentation on the algorithms (or as close as we can get since its proprietary) will be in the Vision Concepts Manual. You can find it by going to Start >> Programs >>National Instruments >>Vision >> Documentation >> NI-Vision >>Vision Concepts Manual. Check that out!
Kristen H.
