11-23-2005 03:01 AM
12-21-2005 10:52 AM
12-21-2005 01:38 PM
12-22-2005 04:42 AM
12-22-2005 05:07 AM
12-22-2005 05:47 AM - edited 12-22-2005 05:47 AM
Message Edited by malef on 12-22-2005 12:51 PM
12-22-2005 06:06 AM
Thanks for the replies guys. I am not looking for great speed but I would hope to be able to do (say) at least 10readings/sec. I know can acheive much faster rates than this using my own OPC client.
Each channel is sampled only every 30 seconds so the conversion time of the Wago A/D isn't an issue for me but there are about 300 channels and I would like to keep the time skew between the first and last channels to a minimum.
Thanks again for the help.
Tony
12-22-2005 07:30 AM
01-04-2006 07:28 AM
For the WAGO-I/O-System there are some additional application notes available on the WAGO homepage
05-07-2007 02:33 PM
Hi Manfried,
As I'm reading your posts I can see thet you are very experienced in comunicating with WAGO equipment. I'm new in this so I need some help. I'm using LabVIEW 7.0 and trying to connect to wago 750-341 via Modbus TCP/IP. I'm using the standard vi's downloaded from wago's web but I'm receiving error 56. What is the problem and what should I do to fix it?
Aleksandar.
