Sum of the elements in an array
Hi guys,
I would like to do this operation with the elements in my 1D array.
Given array:
a
b
c
d
what i would obtain in a new array:
a
a+b
a+b+c
a+b+c+d
could you show me how to do?
Message 1 of 11
(5,048 Views)
I would something like this:
Tim
GHSP
Message 2 of 11
(5,042 Views)
Here's what I usually do
Message 3 of 11
(5,040 Views)
I use this, but save it as a VIM. (Note it will not catch overflow errors for integer types).
mcduff
Message 4 of 11
(5,009 Views)
Well, since the question is a bit vague, here's an alternative interpretation 😄
(... and yes I know there are much more efficient ways ...;)
(well, the subject says "sum", but who knows? ;))
Message 5 of 11
(4,982 Views)
CLA
Message 6 of 11
(4,938 Views)
Here's a method that operates completely in-place, which can be turned into a VIM also.
@terickson wrote:
Neat implementation, but slow for big arrays.
mcduff
Message 7 of 11
(4,920 Views)
Don't underestimate the compiler. Mine (above) has the same number of array buffer allocations. 😉
If you really want to use the IPE, I think having an extra scalar (below) probably compensates for your operating on two array elements with each iteration. Of course you have one fewer iterations, which could make a difference for extremely small arrays.
Not tested, just guessing of course. 😄
Message 8 of 11
(4,892 Views)
+1. This is why I said the VI operates totally in-place. The screen shots below are LabVIEW 2019, using the "Profile Buffer Allocations Tool"
Profile Tool only records 1 bufferProfile Tool only records 1 buffer
Using the VI from the earlier post, which is a bit faster, I see this
Profile Tool records two buffersProfile Tool records two buffers
It's possible the first buffer in the second screen shot is erased immediately after execution; this is @rolfk territory, so in effect 1 buffer. But at least according to NI's tools, there are 2 buffer allocations.
Besides complex numbers I thought you liked to do things in parallel. 🙂
mcduff
Message 9 of 11
(4,884 Views)
I like these threads. Its like when someone asks a in forum to photoshop him holding the sun. (or, no its not quite there yet).
Certified LabVIEW Architect
Message 10 of 11
(4,815 Views)
