Suggestions for setting up a new PXI system
*******Apologies for posting in a different location. I did this to have more suggestions. Orginal post here.*******
Hi all,
We are planning to setup a PXI system for the computer control of our new experiment. I have few questions:
1. Our choice for analog output card is PXIe-6739. The datasheet mentions a maximum update rate of 1 MS/s if we use upto 16 channels after which it drops to 350 kS/s. But it also says this is the update rate if we use one channel per bank (1 bank = 4 channels as per pin-out). This card has 64 output channels, so 16 banks.
My question is, if for 10 banks I use one channel per bank and for renaming 6 banks I use all 4 channels per bank, can I have 10 fast channels with 1 MS/s update rate and 24 slow channels with 0.35 MS/s update rate?
2. Our choice for digital I/O card is PXIe-6537. The maximum TTL voltage it can generate is 3.3 V. Would standard TTL devices (of 5 V) respond to this 3.3 V? OR is there a way to pull-up 3.3 V to 5 V (the easiest way, and not by myself soldering a bank of amplifiers.)?
3. Does NI provide any PXIe/PXI compatible card which can produce a variable frequency time-base (clock) under hardware timing?? I would like to stress hardware timing for precision timing. A similar third party solution is like PulseBlasterESR-CompactPCI (LINK).
4. Are there any BNC breakout boxes for PXIe-6739 and PXIe-6537. The screw terminal ones are the only compatible I know, but we want BNC breakout boxes for these cards if available.
Thanks.
(1,918 Views)
Hi RPB,
why don't you call your local NI representative and discuss all your requirements with him/her directly?
(1,889 Views)
As mentioned, this is a duplicate thread, so let's keep all discussions in one place.. Continued here.
(1,870 Views)
